prop please >
prop please
prop please
Old 05-06-2006 | 08:08 AM
nocigarette's Avatar
Default prop please
i am told by another knowlegable member that i need a 15.25x26 bravo 1 four blade for my 27 mag........I have A#3 speedmaster can you guys help..........
nocigarette is offline
Old 05-07-2006 | 09:03 AM
Nykamp's Avatar
Default Re: prop please
Check with BBlades in wisc. or Throttle up, they should be able to help you, I believe you will need a 19 spline SSM prop to fit a #3. I have a set of 17.5 by 27 3 blades for sale.
Nykamp is offline
Old 05-07-2006 | 10:09 AM
thanks i always appreciate the help
Old 05-08-2006 | 11:15 AM
throttleup's Avatar
You cannot run a Bravo I propeller on your drives but you need to run ## propeller. Call Randy at Cobra Power at 305-893-5018 he has quite a few used #3 props in stock.
Julie
throttleup is offline
Old 05-08-2006 | 09:17 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: prop please
Yes you will need the "older" 19 spline. Call us if you get stuck well put a APB.
[email protected]
bbladesprops is offline
Old 05-09-2006 | 04:17 PM
thanks guy i will be in touch
Sick Stinger
Velocity
9
02-07-2008 11:39 AM
FlyFast
1
08-06-2004 10:22 AM
boatinbill
07-26-2002 09:58 AM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
