Thrust washer for Turbo prop >
Old 05-12-2006 | 07:27 AM
onesickpantera's Avatar
Default Thrust washer for Turbo prop
I picked up an older used Turbo prop in great shape. But I am concerned about the thrust washer. I called Turbo and they said to use the OEM thrust washer #13171(now #8354671) which is what I have.
But, the Turbo prop DOES NOT have a recess for the thrust washer to "drop into" like my Mirage prop does and this concerns me. This seems like it would add a lot of stability.
Here's a pic of the Turbo(top) and the Mirage(bottom) prop to compare.
Attached Thumbnails Thrust washer for Turbo prop-turbo-hub.jpg   Thrust washer for Turbo prop-mirage-hub.jpg
onesickpantera is offline
Old 05-16-2006 | 08:47 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Thrust washer for Turbo prop
I don't have the part number with me now. Call me at the shop and I'll give you the part number for the correct thrust washer. 920-295-4435
[email protected]
bbladesprops is offline
Old 05-17-2006 | 06:15 PM
Default Re: Thrust washer for Turbo prop
Brett, is it #8354671? Turbo told me that should work.
Old 05-18-2006 | 09:34 AM
I guess I'd use what Turbo suggests but, that washer has a step.
I was going to tell you to use a 13191Q1
[email protected]
Old 05-19-2006 | 07:53 AM
Brett, I have to admit Turbo didn't make me feel all warm and fuzzy about it. I would prefer using a non-step washer if possible but I can't find that 13191Q1 part number.
I'll call you later today if I get a chance.
BajaRunner
13
07-18-2006 09:01 AM
1BIGJIM
1
05-08-2006 12:34 PM
Fuhgedaboudit
0
06-13-2004 01:05 PM
duunoit
2
06-06-2003 01:36 PM
kook
1
06-17-2002 12:09 AM
