prop needed on active thunder >
Old 07-13-2006 | 04:52 PM
Default prop needed on active thunder
have a 25 active thunder with 454mag carb motor.turns 23 mirage at 5100 rpm and 67 mph with 1.36 b1.switch to 25 and only pulls 4400-4500 at 63 mph.the front of the boat bounces like crazy.should i switch to four blade?maybe a labbed 23 four blade
awsomethunder is offline
Old 07-17-2006 | 08:27 AM
throttleup's Avatar
Default Re: prop needed on active thunder
I think you will appreciate the performance of a 4B propeller. It really should calm down the porpoising issue. I would recommned starting with a 22P Stock Bravo I and baseline the propeller. If it runs at around 5000 RPM then you could consider lab finishing a 24P Bravo I.
Julie
throttleup is offline
Old 07-18-2006 | 08:03 AM
julie will this cost me any top end?do you still do that testing program?
Old 07-18-2006 | 03:39 PM
throttleup's Avatar
Yes, it is possible to loose 1.5-2 MPH going from a 3B to a 4B but this is really dependant on how well your 3B props is dialed in.
Julie
Old 07-31-2006 | 12:52 AM
Gordo's Avatar
Charter Member #94
Having quite a bit of experience with the 25 Active Thunder, I would highly recomend either trading your Bravo 1 drive to a drive that has a 1.50 gear ratio, or check cost on simply changing gears in your existing drive.
Once you have a 1.50 drive, then get with Julie and look into a 22p 0r 24p bravo-1 4 blade props, (the 25 Thunder loves bow lift). Find the prop that will get close to 4850-4900rpm and send it back to Julie to be Lab-finished. You will be very happy with the results.
Abby-someone
Gordo is offline
Old 08-01-2006 | 08:26 AM
gordo can i keep my 1.36 and just prop to 4900.what is the advantage to switch to 1.50?i run 5100 now 454mag carb is this the correct rpm
Old 08-01-2006 | 05:44 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: prop needed on active thunder
I believe Gordo is suggesting the throttle response you will get by going to the lower gear ratio. Even though the prop will be bigger the boat will respond quicker.
The 4 blade may actually increase the porpoise issue. That problem can however, be dialed out of the prop.
[email protected]
bbladesprops is offline
Old 08-01-2006 | 06:51 PM
cosmic12's Avatar
I would listen to Gordo he is the man on those 35 ATs
cosmic12 is offline
Back4More
Active Thunder
111
08-18-2007 07:45 AM
BAJA WILL
03-03-2007 07:38 PM
Sydwayz
Prop Talk
5
06-06-2005 09:28 PM
ghaskell
2
05-22-2005 07:54 PM
BruceK
Active Thunder
7
08-19-2002 10:26 PM
