Bravo 1 test results >
Old 07-23-2006 | 10:37 AM
GregP's Avatar
Default Bravo 1 test results
Ran a set of Bravo-1's this morning courtesy of ScottC (Thanks!). Got back just before the rain started again. Results were pretty much what I expected going in, they are too much prop for the boat but do have much better mid range and low speed bite.
Boat: 32' Scorpion CC (est 8000#)
Motors: Yamaha TXXR250 (carb) X 2
Normal props: 21" Yamaha saltwater series 3B
Test Props: 22" Bravo 1 (pre-vent hole set)
Weather: 80 degrees 80% humidity
Water: flat (the boat really likes some chop to run)
Speeds: GPS
RPM / Yamaha 3B speed / Bravo-1 4B speed - comments
1000 / 6.5 / 7.2 - can't run in no wake under 6 mph with either set on both motors, need to idle around on just one (they will idle slower but load up if kept there too long)
3500 / ** / 35 - the 3B's won't run between 3000 and 4000 as they keep blowing out. Being able to run in the 3-4k range is one of the things I want from new props for maneuvering through traffic
4000 / 35 / 40 - big speed advantage in mid range just as you would expect
5000 / 49 / 52 - still a good speed advantage, but 5000 is all the Bravo 1's will pull
5400 / 54 / **
Around 4000 RPM the Bravo 1 definately feels like it wants to bow steer unless you trim out much further. The Bravo 1 will hold a LOT more trim than the 3B, but it also needs much more trim to pull the RPM.
I hope to test a set of 21" Rev-4's in a couple weeks.
-Greg
GregP is offline
Old 07-24-2006 | 01:27 PM
throttleup's Avatar
Default Re: Bravo 1 test results
Let us know how your testing goes.
Julie
throttleup is offline
articfriends
17
04-28-2007 12:31 AM
Boomer 880
Active Thunder
4
07-06-2006 08:01 PM
Jgray
6
08-08-2005 07:52 AM
Hy-Velocity
13
03-07-2005 11:45 PM
Intolerant1
08-07-2002 12:48 PM
