Cleaver To Lightning >
Old 08-11-2006 | 08:00 AM
Default Cleaver To Lightning
Brett Is Working On A Project For Me Converting A Monster 18 Inch 3 Blade Cleaver Into A Bowlifting BI-CH For My Single Engine Application. It Will Look Something Like A Lightning . Who Thinks It Will Work. If Anyone Can Do It Bblades Can. Time Will Tell. Who Knows Speedmasters And What Do You Think ? I Will Post Results When Finished .
z.zuperboat is offline
Old 08-11-2006 | 09:05 AM
lightspeed's Avatar
Default Re: Cleaver To Lightning
Think It Will Break 50
lightspeed is offline
Old 08-11-2006 | 09:07 AM
jOHN THAT WAS YOU IN THAT BIG CAT THE OTHER DAY ?
Old 08-11-2006 | 12:14 PM
I have an old heavy cigarette 38 flat deck with Arneson drives on it. I run Hoss props reworked by Bret and Bob, they lift the bow so much better than cleavers it is not comparable. As added benefit they are around 5 - 7 mph faster than the cleavers.
Thanks BBlades for the recent quick turn-around on my prop.
Kris
kvogt is offline
Old 08-11-2006 | 05:05 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Cleaver To Lightning
As always Kris, your welcome!
Did you slash the new prop yet?
[email protected]
bbladesprops is offline
Old 08-15-2006 | 03:23 PM
IRONMAN's Avatar
Keep us posted, I am interested in what happens. I have found that just going from 17 diam to 16.5 made a very noticeable improvement in bow lift. Slippage increased some but the control and handling is much better. Chris
IRONMAN is offline
Old 08-16-2006 | 06:31 AM
My 4 Blade Started At 17 Then Cut Down To 16.5 With Negative Results Then Back To Mercury Again To Try More Mods, Cut Down More To 16 With Some Tip Work And Still No Good Resluts. So After Being Charged Twice Still With Negative Results I Was Done With Mercury. Not Knowing Brett Was Gone My Fault!!! Got The 3 Blade Back Yesterday And Looked Very Impressive. Thin, But Not To Thin. I Should Have Results By The Wekend.
Old 08-18-2006 | 05:59 AM
Ok We Have Some Results On The New 17/34 3 Blade. ( First The Good ) The Boat Picked Up 4 Mph. Also Picked Up 300 Rpm. I Still Have Some Room In The Rpm Range That Mite Help. ( The Bad ) Lost 6 Mph In The Midrange And The Slip Went Up From 17 To 18 If My On Line Prop Calculator Is Correct. All In All Prop To Prop Brett Gave This Prop On This Boat A 4 Mph Gain. Thats A Thumbs Up In My Book.
Old 08-19-2006 | 08:06 PM
Awesome, glad to hear we gained the top end. That's what we were looking for. Mid range and top speed don't always go to gether. I wish that wasn't so.
I got your call message. We'll talk next week.
[email protected]
Maritime_Eng
Prop Talk
1
09-08-2008 12:45 AM
onesickpantera
Prop Talk
13
08-25-2008 07:22 PM
gerard
06-20-2008 07:42 PM
Playtime
Prop Talk
0
06-16-2007 07:16 PM
nordic95
Prop Talk
3
03-25-2007 08:25 PM
