Bravo-1 vs. Revolution-4 (Labbed vs. Stock)
Originally Posted by bbladesprops
25 is the largest Rev 4 made. I am still lobbying for 27's but with all the other things going on right now, my wishes are falling on deaf ears. I know we would have many applications they would work on.
How does the Turbo Fusion 4 compare to the Merc Rev 4?
The Turbo comes in larger pitch sizes.
Patrick
Patrick
Just an FYI:
Got a chance to test a 23" Rev-4 on my Baja 232 this week. Although I have tested with both a 23" Mirage/PLUS and a 22" Bravo/1 reaching a max speed of 66-67mph, both running as smooth as silk in 1' wind chop.
The Rev-4 was quite different. Running offshore in 2' seas, the Rev-4 performed pretty well but seemed a bit "loose" all morning, not terrible, but not a solid, hooked-up feel like the Bravo/1. When I made my first high-speed pass behind the breakwater, at about 60mph I began to experience a somewhat violent chine walk which seemed to intensify as the speed increased. It became a bit scary so I throttled back at about 64mph and didn't loose the chine walk until I slowed to about 40-45mph.
I have never experienced chine walking before on this boat and the only thing which was different was the new Rev-4 prop I was testing. I am assuming this prop has some design characteristics which may have been the cause?
Originally Posted by AIR TIME
can you take both props with you and test one and go back test the other the same day.
Pat,
We have seen the Fusion 4 run similar to the Rev 4. The Rev 4 is typically 1-2 mph faster. However, the F4 comes in pitches to 32! And, the higher pitches, are higher in rake angles.
[email protected]
[email protected]
pat's got it...
at least from my experience....my revo4's work exceptionally well on my "old school" 87 sutphen rumrunner, twin 350mags
42mph at 3000rpm, 54@3800, tabs down a bit past parallel, drives out just a bit above parallel..the mid range handling and cruise are awesome...
c
c
FYI ..... I'm interested in selling my 23p Rev-4.
Bought new-in-the-box for testing, it's a 23" pitch RH 4-blade Mercury SS propeller (48-857030-A46) which has been used for less than an hour and is in absolutely MINT condition with no dings, scratches or nicks. $275
PM if interested.
PM if interested.
