Throttle Up Raises the Bar >
Old 09-15-2006 | 02:44 PM
  #31
throttleup's Avatar
Default Re: Throttle Up Raises the Bar
The rake angle is a little less on our props than a Maximus. Typically when you get into the higher pitch range boats usually don't need as much rake in the props. This is due to many factors including boat design.
The Maximus prop has a lot of cup in the tips of the blades. Keep in mind that Mercury needs to make a prop that out of the box will work on a wide variety of boats. Hence their props have to be made so they will fit a wide range of applications. Mercury sells the same props to boat manufacturers and their props need to work on all of them.
Matt
throttleup is offline
Old 09-15-2006 | 02:59 PM
  #32
BajaBennett's Avatar
Julie,
Congratulations on your new product line. The best just keeps getting better!!!!
Thanks,
Dail Bennett
BajaBennett is offline
Old 09-15-2006 | 04:01 PM
  #33
throttleup's Avatar
Thank you all, for the inquiries and positive support this week!
Julie & Matt &
The Staff of Throttle Up Propellers
Old 09-15-2006 | 07:40 PM
  #34
Vinny P's Avatar
I hate the winter!!
As I have always said, you guys are the best.
Vinny
Vinny P is offline
Old 09-15-2006 | 10:53 PM
  #35
Before Throttle-Up came out with the CNC props, every set of props we ordered was a gamble.....and every prop had to be tweaked.
Now, with CNC machining and finishing you are guaranteed that left hand prop will be exactly like the right hand prop. You can also be assured that if you need to replace a prop, the new prop will be an exact duplicate of the previous one.
No more guessing, no more time and money wasted on testing and tweaking.....you get the exact same prop every time.
70% of the time we put on the race boat has been testing...and 80% of that time was for checking and tweaking props. With the CNC props, once you have your setup...your done.
Com'on oyster beds, sand bars, and underwater monsters...eat my props. I can get another set exactly like these.
Ken Doyle
Mid-American Offshore
SBI/APBA Super V #10
KenD is offline
Old 09-15-2006 | 11:00 PM
  #36
The most important benefit..............they are FASTEST Props we have ever run!
KenD is offline
Old 09-16-2006 | 06:34 AM
  #37
throttleup's Avatar
Thanks Ken. We will spend the day today at the 10th street boat ramp in Sarasota testing, testing, testing. We will be testing on several race and pleasure boats further validating the performance of our CNC props.
Looking forward to finalizing the dialing in on your boat, Ken.
Matt
Old 09-16-2006 | 06:49 AM
  #38
throttleup's Avatar
Our CNC props are available in either a polish finish. Or a machine finish.
Old 09-16-2006 | 07:58 AM
  #39
How Many Different Shafts Will Be Available ? I Run A 19 Spline Speedmaster Longshaft. Run A 16x32 4blade At 6000 Rpm Always The Slip On The 4 Blade Is 13% And My 3 Blade Is 18%. More Blades Less Slip
z.zuperboat is offline
Old 09-17-2006 | 07:07 PM
  #40
SeaRay Jim's Avatar
Originally Posted by TxFountain
SearayJim, I think I tried to make the point that I would like to see a ballpark price. Sorry you had a problem with that.
I didn't see anything that said call for prices.
I had no problem, it was just a tongue-in-cheek comment but I admit, I was also was thinking at the time about how pricing being discussed in forums by vendors was generaly prohibited (hence why I assumed the comment was made to Sea-Dated) and didn't think about the fact that I'd never seen that with OSO.
My bad. I'll sit down and go back to my drink now.
SeaRay Jim is offline
