what prop nexted >
what prop nexted
what prop nexted
Old 09-27-2006 | 07:22 PM
AIR TIME's Avatar
what prop nexted
HI ALL , to day I got some good #s finely 5600rpm 26b1 labbed baja ol 24 4000lbs 2'' shortie 380s kplanes on #6 to 7, 2 to 3 foot chop that I got the repeat speed of 83.2 gps on the flat water I was getting 80 to 81gps trimed up alot I think ,so should I go to a 5 blade for more speed and bow lift or stick with a b1 28 labbed for more bow lift, what is my slip with the b1 26, 5600, 83, 1.5gear? thanks
AIR TIME is offline
Old 09-27-2006 | 07:52 PM
99fever27's Avatar
Default Re: what prop nexted
I would be interested in the 26 Bravo if your thinking of selling it.
99fever27 is offline
Old 09-27-2006 | 09:29 PM
iamfaster's Avatar
what motors? what r's are you making peak power at? it is rare that a 5 blade is fastertop end then the 4 blade bravos. dont know the formula but your slip #'s seem decent?
iamfaster is offline
Old 09-27-2006 | 09:31 PM
iamfaster's Avatar
sorry...above post was supposed to be for air time
Old 09-27-2006 | 09:44 PM
AIR TIME's Avatar
motor was a merc 510 647hp at 5900 I THINK, DON'T HAVE THE DYNO SHEET ITS AT NICKERSONS AND TQ WAS627 AT 4800 THAT WAS WITH OLD CARB 850 BG WITH 82/82 JETS THE OLD SET UP i WAS HITTING A WALL AT 5100RPM ONLY GOT 74 OR 75 MPH.
AIR TIME is offline
Old 09-28-2006 | 08:01 AM
throttleup's Avatar
AirTime,
I have calculated your slip at 5% ....but unfortunatly it is not likely that 5% is accurate. The range on a 4B is 10-14% and typically Vee Bottoms are not less than 5-6% with 6B props. So I would recommend that you verify your data so as to not chase any ghosts.
Julie
throttleup is offline
Old 09-28-2006 | 08:55 AM
AIR TIME's Avatar
so the gps could be off that much? 2 weeks ago with 100gals I goy readings of 78gps and on the river yesterday in the flat for a hour up and down I WAS GETTING READINGS AT 1ST OF 79 TO 80 then I went out to the bay where after a while I got readings of 83.2 83, 82 ran from one end to the other I was sitting in the bolster so the tach reading might of been 5800? on the river I was standing and the tach was at 5600 with the 79 to 80gps. well going out on sat and will have a rider hold on to the hand held gps, and I will watch the gafrig dash one. going to check the gas tank sender to day so I will know if IO am running low. this is a labbed 26 not sure if was made to a 27 either it was done back in 2002 a 28 was to much back then. drive was to deep.
AIR TIME is offline
Old 09-28-2006 | 01:09 PM
throttleup's Avatar
I think it is a good idea to verify tahcs and GPS's. Is there a strong current in the waterway that you boat? If so this could accopunt for things as well. Let us know what you come up with this weekend.
Julie
Old 09-28-2006 | 06:29 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: what prop nexted
I calculate your first readings more in the 7% range. The efficiency drops as the speed does. The slip then goes in to the more common 10-11% range.
We see many boats run under 10% with 4 blade props. However, very few are Bajas. Going to a 5 blade on your application will most likely not improve the top end numbers. We can test with them if you like.
Labbing the current Bravo 1 props to get into the upper 5000's is a likely option. The Labbing would need to be done to fit your specific needs. Let us know when you get the most accurate numbers.
[email protected]
bbladesprops is offline
Old 09-28-2006 | 08:29 PM
AIR TIME's Avatar
I will be going out sat and will bring hand held gps too.no one on this site has ever run a ol 24 with the 2'' shortie ,the prop shaft and the pad is 5 1/2 '' and the prop was labbed back in 2002 .I TALKED TO ONE PERSON THAT HAD A 1'' SHORTIE RAN 1300HP AND DID OVER A 100 AT LOTTO SHOOT OUT A COUPLE OF YRS AGO. OH well at lest its faster than last yr74 at5100 whats the slip for that or what the cal?
AIR TIME is offline
