Changed drives and starting over >
Old 11-12-2006 | 10:49 AM
Default Changed drives and starting over
I have recently swaped drives for a B-Max with a 1.30 ratio. During break in I ran my labbed 30 Bravo 1 @ 4400 to 4500 around 82 GPS the only other prop I have been able to run so far is a stock 26 Bravo with a damaged blade similar speed at 5200 to 5300. Before the swap ran Bravo 1 drive with both 1.50 and 1.36 best speed was with 1.5 and a 32 stock Bravo @85.8 GPS but it would bury the bow my labbed 30 rode better but lost a couple 10th's. Running the 1.36 cost me about 1 to 2 mph with same props.
The boat is a 26' 280 Velocity modified and Pro-Charged 454 Mag with 5lbs boost no dyno numbers, estimations are 700 to 750 hp.
Any thoughts?
RBeyer is offline
Old 11-12-2006 | 07:08 PM
articfriends's Avatar
Default Re: Changed drives and starting over
what rpm's were you turning before,Smitty
articfriends is offline
Old 11-12-2006 | 07:11 PM
Smitty,
5400 to 5600 a little more maybe with the 30 and less with the 32 but close.
Bob
RBeyer is offline
Buddy OO
Black Thunder
15
02-05-2007 09:52 PM
Boomer 880
04-07-2004 12:57 PM
later
12-17-2003 07:18 AM
Raypanic
13
05-22-2003 08:16 AM
