23 3 Blade To 24 4 Blade >
Old 01-16-2007 | 02:55 PM
Default 23 3 Blade To 24 4 Blade
want to switch from 3 to 4 blade to help carry the bow but i think a will loose 400 rpm.labbing will get 200 back,anyway i can get the other 200.can you tweak a 24 pitch to 23
awsomethunder is offline
Old 01-16-2007 | 04:10 PM
Default Re: 23 3 Blade To 24 4 Blade
If you are running a Mirage plus, thats about the most bow lifting prop you're gonna find. A Bravo 1 4 blade carries the bow about as much as any 4 blade can, but still not as much as a mirage plus.
If you're running a 23 Mirage plus, go to a 22 bravo 1 and have it cupped for more bow lift. You will most likely incresed cruise speeds and a loss on the top end.
Griff is offline
Old 01-16-2007 | 04:31 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: 23 3 Blade To 24 4 Blade
Four blade props do offer more stern or over all lift. If we go to the 24 Bravo 1 and Lab it to carry the bow better, It will bring your rpm's right back in line with the 23 Mirage Plus.
We have test props to aid in your decision. We can base line box stock Bravo 1's and make a decision from there. Otherwise, I'm sure the Labbed 24 will get you where you need to be with overall performance gains.
Call us if you have any other questions.
[email protected]
bbladesprops is offline
Old 01-17-2007 | 10:12 AM
brett i will give you a call in the spring,may do some engine mods next month and don't want to buy the wrong prop
Old 01-17-2007 | 05:59 PM
Sounds good. If you ever need test props, give us a call.
[email protected]
Old 01-17-2007 | 07:07 PM
StillHaulin@63's Avatar
Exactly what I did for my Baja 232 (454 Mag MPI)
New B1-22p cupped to a 23p (not labbed) and it's perfect.
You'll love the 4-blade bite too!
PS: Almost identical top end because of less slip!
StillHaulin@63 is offline
fandango
Wanted
6
05-15-2008 07:14 PM
Inspector
Prop Talk
1
07-09-2007 07:50 AM
LFarr
Prop Talk
11
08-25-2005 07:09 AM
wtpowered
Prop Talk
7
07-04-2005 02:34 AM
Intolerant1
04-08-2002 08:08 AM
