Prop for a 15' Whaler >
Old 01-18-2007 | 08:27 AM
Pat McPherson's Avatar
Question Prop for a 15' Whaler
A friend of mine is reriging a 1978 15' Boston Whaler with a 1999 70HP Johnson.
Not looking for top end speed as we have other boats for that.
He will be pulling skiers, tubes, and going fishing.
Looking for pulling power and the most stable ride.
How about a 4 blade aluminum?
What pitch to try?
Thanks,
Patrick
Pat McPherson is offline
Old 01-19-2007 | 09:30 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Prop for a 15' Whaler
Hey Pat,
Merc doesn't have a 4 blade for that motor. have to get to the V4's for the hub changes. Mich wheel has 4 blades in aluminum for the small and big gear cases. The large case is what you need, I think. They have 10 and 12 pitch. Probably too small. How about a 3 blade stainless? Good durability and better performance out of the whole than a aluminum.
[email protected]
bbladesprops is offline
Old 01-19-2007 | 12:04 PM
Default Re: Prop for a 15' Whaler
Hi Brett,
I did find a 4 blade aluminum prop. What do you think?
http://www.solas.com/products/propel...No=S02&PdKd=AL
Yes, Gregg will likely buy a stainless performance prop eventually, but his wife and kids are going to run this boat too.
Thanks,
Patrick
Old 01-19-2007 | 12:16 PM
Yeah, if you want unique stuff, or you can't find it anywhere else, Solas or Mi wheel are go to's.
The problem is the QC on those props isn't always the best. I think a Silverado 3 bl stainless from Merc will perform better on the top and as well down low. I think the prop you are talking about is very reasonably priced so that trying it would be cost prohibitive. If he likes it, great! Otherwise we can try some stainless.
Take care
[email protected]
Old 01-20-2007 | 04:50 PM
TWC
Pat,
Try a Stiletto Bay Pro I four blade stainless steel propeller. 13-1/4" diameter and pitches from 13" to 19" are available.
TWC is offline
Old 01-20-2007 | 11:10 PM
MI wheeel
[email protected]
Old 01-21-2007 | 08:53 AM
Hey Brett,
I received two used props I bought last week.
The M+ is in great shape so I'll try that as is before sending it to you for tweaking.
The Mach I received is a bit rough so I'm not sure if I should run it as is. Do you have the dies to bring that prop back to its stock shape? It is a ø14.5 x 28p round ear stern driver.
Patrick
Old 01-22-2007 | 05:12 PM
Check you email inbox.
[email protected]
Old 01-24-2007 | 09:16 AM
Thanks Brett,
I'll be sending two props your way early next week.
Patrick
Old 01-24-2007 | 07:29 PM
I have a 97 15 BW with a 13 pitch 3 blade (aluminum I believe) that is turned by a Yamaha 60 HP 4S. Boat runs 41 MPH GPS but chine walks really bad above 39-40. Out of the hole is fair.
Jupiter Sunsation is offline
