prop help >
prop help
prop help
Old 01-30-2007 | 12:06 PM
Default prop help
currently running factory supplied prop Maximus 5-blade,15 5/8 x 28. Formula Fastech 2006 353 w/525 EFI's. Turning 4700 rpm @ wot. 80 mph gps. What size/type propeller to maximize available rpm?
ddituro is offline
Old 01-30-2007 | 07:27 PM
Default Re: prop help
Do you have boxes or ITS????
My freind has 500EFIs, Stellings and 30" bravo's. He gets about 84mph. You should easily get 85mph+ and you need to get the rpms around 5200. You would need to come down 2" in pitch from the 28's you have now.
Griff is offline
Old 01-31-2007 | 01:36 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: prop help
Don't switch propellers. Let's get the big pitch to turn higher in the recomended range. Have them Lab Finished. Your efficiancy is excellent right now! We can get 400 rpm out of those propellers. 5mph gains are within reason!
If you like the way the boat handles and performs over all. Stay with these propellers. You already own them and the propellers can be adhanced to optimize the performance. If we go to 4 blade propellers you will lose cruise speed to only gain a minor amount of speed over the Labbed Maximus propellers.
[email protected]
bbladesprops is offline
Old 01-31-2007 | 05:22 PM
I do not have boxes or its. Bravo xr drives with 1.5/1 ratio.
I was under the impression that these props are labbed at the factory, cant by them any other way.
ddituro is offline
Old 01-31-2007 | 06:50 PM
Smile Re: prop help
Oh you can buy them box stock every day. I sell them in a variety of configurations.
I used to take all the orders from Kim Post at Thunderbird for all the Mercury propellers. The props you have will be stamped on the top near the prop nut if they have been worked by Mercury. Check there and let me know what you find. We can discuss it from there.
[email protected]
Old 02-12-2007 | 12:10 PM
I was finally able to get to my boat this weekend, the props are already labbed. What would be the next step.
ddituro is offline
Old 02-12-2007 | 01:39 PM
Smile
Can you supply us with the hand stamped serial # on the hub of the propellers? Then we should talk about it. Mercury changed their formula 3 times for these props after I left, only to return to the recipe we originally developed. Since you have a 2006, you probably have the latest and greatest. This means other options could be investigated.
[email protected]
Old 02-24-2007 | 02:28 PM
The hand stamped numbers are:
Starboard; P11ul or Pl1ul.
Port; C11ul or C1lul
ddituro is offline
Old 02-24-2007 | 06:30 PM
Smile
OK you have pretty standard templated Labs. There still are things to be done to the propellers to increase the rpm and the top end speed. We will need to see the props to make the ultimate decision but, I think a very small diameter decrease with thickness adhancements and a couple tricks could get you to the 5000 mark. This will maintain the cruise and really help the throttle response and WOT speed.
[email protected]
Sick Stinger
Velocity
9
02-07-2008 11:39 AM
FlyFast
1
08-06-2004 10:22 AM
boatinbill
07-26-2002 09:58 AM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
