More prop help please! >
Old 03-27-2007 | 09:30 PM
Default More prop help please!
Well guys I am nearly done with my 250 B&M install on my HP500... I need a little prop advise..here is what I had
HP500 w/500hp @ the prop (I massaged the original engine)
Bravo1 outdrive 1.5 :1 ratio
Bravo1 24* labbed
I was running 62mph @ 5100RPM
boat weight around 5000lbs
My blower install should net me around 675-700hp @ prop
I want to run about the same RPM..5100 ish
What prop? I want to stay with a 4 or 5 blade for handling though.
Bajapred is offline
Old 03-28-2007 | 07:36 AM
gsmith9898's Avatar
I would put on the 24 and see where your at. You are getting close to needing a xr drive( I just happen to have one) than you can get with Brett at bblades to see what prop you really need(if any).
gsmith9898 is offline
Old 03-28-2007 | 08:28 AM
Pat McPherson's Avatar
If you like the way she handles with Bravo 1 props, than try those first.
With the extra 150+HP you are going to need more prop for sure. Likely a stock 26p or labbed 28p B1...
Patrick
Pat McPherson is offline
Old 03-28-2007 | 09:10 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
I true 600 hp will bring you into the 26+ range.
[email protected]
bbladesprops is offline
Sick Stinger
Velocity
9
02-07-2008 11:39 AM
FlyFast
1
08-06-2004 10:22 AM
boatinbill
07-26-2002 09:58 AM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
