Best Prop Wrench? >
Best Prop Wrench?
Best Prop Wrench?
Old 04-27-2007 | 09:16 PM
Rebel_Heart's Avatar
Default Best Prop Wrench?
I am going to be changing props quite a bit in trying to find the best one. What is best prop wrench? Where did you purchase? Thanks.
Rebel_Heart is offline
Old 04-28-2007 | 08:08 AM
I am not sure,I just use a socket and torque wrench. A Merc. mechanic told me don't buy one of those floatable prop wrenches.He said they flex and you won't be able to get the prop nut tight enough. Just some food for thought.
johnny b good is offline
Old 04-28-2007 | 09:52 AM
I don't know if mine floats but I found a Merc prop wrench in my local marine store for $10. That wrench, a section of 2x4 and a set of pliers has worked fine for me; don't forget spline grease if they're new props.
I think it's only 55 ft-lbs on the nut; big thing is to have the tabs on the washer bent down correctly.
handfulz28 is offline
Old 04-28-2007 | 01:16 PM
99fever27's Avatar
I bought one of those yellow plastic floating prop wrenches. The first time I used it, It slipped of the nut and sent my hand flying into the prop blade!!! Never again, its living its life in the dump somewhere.
99fever27 is offline
Old 04-28-2007 | 01:52 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
A 6"-9" breaker bar (stainless steel), and 1 1/16" deep socket. Also a 1" extension between the two helps.
Tape the stuff together at the joints with electrical tape (it bends). That way parts won't come apart and drop in the drink. Also, most small breaker bars have a hole in the end of the handle. Good place for a piece of leather strap for your wrist. I've lost quite a few.
The plastic ones are good for 2-3 uses.
[email protected]
bbladesprops is offline
Old 04-28-2007 | 03:33 PM
t500hps's Avatar
21 and 42 footers
Bougth a 1 1/16 deep well and a 18 inch breaker bar.....So what it doesn't ratchet, I needed something easy to stow on the boat.
t500hps is offline
Old 04-28-2007 | 06:41 PM
el indio's Avatar
no wonder i have been having problems all these years.i have been using a vice grip and putting it in gear.............
el indio is offline
Old 04-29-2007 | 12:16 AM
Thanks for the replies. Guess, I won't waste my money on one of those prop wrenches.
JoeD
11-14-2007 12:23 AM
358player
07-02-2007 02:33 PM
teaguecustommarine
New Products and Member Discounts
0
03-02-2007 01:05 PM
teaguecustommarine
2
12-15-2006 05:25 PM
stevesxm
2
10-18-2006 11:18 AM
