28's revving to high on 292 Fastech >
Old 04-29-2007 | 02:24 AM
Default 28's revving to high on 292 Fastech
I just took delivery this week of an 2003 292 Fastech with counter-rotating twin 6.2L's, 1.65 Bravo 1's and 28" pitch props which I believe were the stock props from the factory. I took the boat out for the first time today and had a blast with it. I hit 72 on my GPS but my tachs were reading 5300 RPM which is just over the high end of the max RPM range of 4800-5200. I was wondering if I should look at going to 30" props to get the RPM's down to the lower end of the max range. Any thoughts?
pfbanker is offline
Old 04-29-2007 | 03:18 AM
If it was cool out and you had a light load, I would leave them alone. If it was warm and you had decent load of fuel and gear, then I would look at having them repitched to 29's or getting some labbed 30's.
Griff is offline
Old 04-29-2007 | 04:50 AM
Default Good point
It was cool out and I had a medium load so maybe that was the problem. I'll give it a while and see but may pick up a pair of labbed 30's just for fun. Where is the best place to pick some up?
pfbanker is offline
Old 04-29-2007 | 10:45 AM
BBlades........They know whats up..
creeper is offline
Old 04-29-2007 | 01:00 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
You're in a great position to gain performance within your mid range cruise speeds and in the WOT top speed. Labbing 30's for your hull design should give you a couple in the middle ands get you to the 75+ mark on the top.
With the change in temps. and load you will still run above 5000 with the 30's.
[email protected]
bbladesprops is offline
Old 04-30-2007 | 02:48 PM
Default Thanks
Great, thanks bbladesprops. Sent you a PM for pricing info.
pfbanker is offline
Phazar454Mag
12-20-2007 05:52 PM
vscorsa
12-15-2007 08:21 AM
firstoffshore
04-27-2006 07:22 PM
4mulafastech
12-01-2005 07:54 PM
HelmPilot
10-05-2004 02:07 PM
