Prop help >
Prop help
Prop help
Old 09-05-2007 | 10:18 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
What can I say, Baja's love 3 blade propellers! Dennis told people for years, I have been telling people for years and other are learning that 3 blade propellers work great on Baja's. (shhhhhh don't tell any one)
Now that being said, larger Baja's can benefit from multi blade propellers if the goals change and if the HP is BIG.
Custom Labbing of the 3 blade props may be the next move.
That will be $500
HEHEHEHEEHE
[email protected]
bbladesprops is offline
Old 09-06-2007 | 08:32 AM
throttleup's Avatar
Originally Posted by bbladesprops
Not to disagree with you Julie but we have seen many true V's under 10%.. However, higher slips on true V's often produce better top speeds. Slip % can be over rated. If the 3 blade runs 6%, the 4 blade will be close too. It could actually be higher than the 3 blade for various reasons
I think what Julie may have meant was, anywhere under 15% is acceptable on a hull such as your's.
My thoughts are, Lab the Mirage Plus props. You have rpm room to grow and 1.5 mph is definately in reach.
Exactly Brett. Many boats will perform out of the normal range, but again this is indeed a case by case situation. For instance, newer Fountains run their fastest with a higher % of slip. And I to have worked many a Baja with very low slip numbers...below the 10% with a 3B propeller.
Julie
throttleup is offline
Old 09-06-2007 | 11:00 AM
That will be $500
HEHEHEHEEHE
Checks in the mail. LOL
unbroken is offline
Sick Stinger
Velocity
9
02-07-2008 11:39 AM
FlyFast
1
08-06-2004 10:22 AM
boatinbill
07-26-2002 09:58 AM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
