need prop help on a 28 cat >
Old 09-23-2007 | 10:37 AM
hoozeyurdaddy's Avatar
here is a question for you prop guru's, I'm running a 28 profile cat, 622 ci bowtie, natrually asperated, dyno # 827hp@5800 rpm, 834ftlb's @ 4700 rpm, Imco SC drive with stand off and 3 inch rise, drive ratio is 1.34 at 5600 rpm w/ 26p B1 runs 95 mph on gps, at 5200rpm w/26p B1 runs 88 mph on gps. hers's the question, if I run the slip #'s for a 26p B1 it's around 7.8% if I run the slip #'s for a 25p, which is what they claim I sould use it is around 4.0%, which # is correct, and is it possible to get that little slip out of a stock 26p B1, If I change over to a 5 blade will I get more speed.
thanks
Larry
hoozeyurdaddy is offline
Old 09-23-2007 | 02:34 PM
throttleup's Avatar
You are correct in that you should use 25P when calculating slip. Now assuming that your numbers are accurate I would suspect that a 5B would possibly slow you down. At 4% you you are dialed in VERY well! Nice job!
Julie
throttleup is offline
Old 09-23-2007 | 04:51 PM
what would happen if I had the 26p B1 Labbed?
Old 09-23-2007 | 06:50 PM
throttleup's Avatar
As long as no pitch work was done the pitch would still be the same regardless of finish.
Old 09-23-2007 | 07:44 PM
whould it be worth the money to lab it, would there be any increase in rpm?
Old 09-24-2007 | 07:58 AM
throttleup's Avatar
You would experience about a 250 RPM increase over it's stock RPM.
Julie
hoozeyurdaddy
Prop Talk
0
05-16-2008 09:44 AM
pearlyellow
Prop Talk
4
09-05-2007 10:08 PM
johnnyboatman
4
08-24-2004 07:58 AM
batboatracer
3
07-07-2002 11:41 PM
Fountain38
07-01-2002 10:19 PM
