Gear,Prop help please!! >
Old 12-12-2007 | 02:53 PM
Biggus's Avatar
Originally Posted by bbladesprops
bajabob, your slip is under 8%. That's great for any boat including a Baja!
Brett, Is less than 10% slip actually possible on a straight bottom V-hull?
Biggus is offline
Old 12-12-2007 | 04:25 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Possible yes, likely no. Baja's usually run in the11-12% range when they are dialed in. People may say otherwise but ussually there is a missing link in the equation that brings the slip over 10% when you look at it closely. Under 10% is often on a given day with light loads and perfect water.
High slip numbers can mean the best top end speeds on straight V's so, slip isn't always the enemy.
[email protected]
bbladesprops is offline
Old 12-12-2007 | 09:53 PM
i run my boat in river2riders 50 gallons gas70 mph all the time on gps no bs now builting dart 540 going to dnyo motor shooting for625 hp i no in 2 weeks then i need get new prop hoping to get 80 mph or better got any guest on prop
bajabob is offline
Old 12-12-2007 | 09:55 PM
bajabob is offline
Old 12-13-2007 | 08:48 AM
Smile
bajabob, I believe you have those numbers. Some do! Most don't.
You will need about 2 more inches of pitch depending on the desired rpm levels for WOT.
We have test propellers when you are ready.
Brett
[email protected]
Old 12-13-2007 | 01:40 PM
i call in may i will test boati am puting all new parts my motor is set up for 3000 to 5200 for power i no when they dnyo it
bajabob is offline
SmallPP
0
03-08-2006 08:10 AM
TomZ
12
05-26-2005 01:54 PM
Goofy1103
22
04-07-2005 01:13 PM
X-Rated30
8
08-08-2003 08:34 AM
BGIII
1
12-30-2002 01:24 AM
