Can a single vee actually air completely out below 100 mph?
I was testing my 272 baja a few weeks ago and was running fairly light,I previously have had the boat into the very high 80's (89.5-89.8) hundreds of times with a 30 pitch labbed and std length 1.50 ratio drive and have ran into the low 90's (92.5-92.8) a couple dozen times turning a 32 pitch labbed 4 blade under ideal conditions/light load. The boat now has another 100 hp (running 1057 hp with the pulleys on my blower) and I can easily go past 95 mph towards 97-98 mph top end.
Anyways,I was running pretty light and when the boat pulled past 93-94 mph it felt like it lifted up in the air another foot higher then it usually runs like the only thing in the water was the drive (like in the cartoons
). You could feel a sensation like the crosswind was blowing the boat around in the air,is it really possible that a 5000 lb 27 ft v-hull could be totally aired out at that speed or was I just imagining that? I know other guys with similar boats that have ran even faster that weren't driving on just the drive,but they have all been running shorty lower units where I am running a std length drive.My understanding is that if the boat is actually aired out like I thought it was even a slight change in the wind is going to cause boat to spin out of control. I now have reservations about running that fast again and think I'm going to set boat up to run around 93-94 mph top out,everyones been telling me I have exceeded the hulls limitations but I have been hearing that since the boat broke into the 70's and honestly in the right water conditions it still feels pretty solid as high as 92-93 mph,Smitty
Smitty,
I had my old 27' Checkmate at 104mph and it never felt like it was as aired out as your describing. Were you running a lot of trim? If you have K-Planes were you running them level or raised? At very high speeds I always ran mine level with the bottom of the hull. Seemed to add stability.
Smitty,
