prop slip #'s for B3 >
Old 11-08-2007 | 08:54 AM
hoozeyurdaddy's Avatar
Default prop slip #'s for B3
do you use the same figures for slip on a b3 as on a b1, and is there any difference for twin application, working on a 32 searay cruiser and can't figure out what the slip is or if the numbers I have are correct.4300rpm,1.81gr,22p,30mph, slip comes out to 39%, is that right. boat weight,12,500lbs, T-vortec 350's with 4bbl's, It's a pig out of the hole.
any Idea's?
hoozeyurdaddy is offline
Old 11-12-2007 | 08:43 AM
come on b blades and throttle up, you guy's have to have some input here.
Old 11-12-2007 | 09:12 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Sorry for the delay.
Your calculations are correct. We do use the marked pitch in the equation. I don't know why your slip #'s are so high. It is unusual for any Bravo 3 boat to run that high. Verify the tachs and speed are correct. Also the gear ratio.
[email protected]
bbladesprops is offline
Old 11-22-2007 | 07:39 PM
adjust yer carb, bo
jwpotts0413 is offline
verbi69
Prop Talk
12
12-28-2008 07:33 PM
Rookie
5
08-12-2004 12:05 PM
outriggers
2
06-03-2004 08:38 AM
wwwTOPDJcom
06-04-2002 12:19 AM
