Mercury Prop Warranty? >
Old 02-21-2008 | 04:12 PM
FeverMike's Avatar
Default Mercury Prop Warranty?
I have a Bravo 1 26P prop on my center engine that threw the tip of the blade off. There is not a mark on my skeg and the other blades on the prop are clean with zero signs of abuse or hitting bottom.
It looks like a defect in the casting and a clean break right off. No bent metal or like anything cut it off.
This is the stock prop that came with the boat and I have owned it 2 years with only 165hrs on it.
Does anyone if Mercury warrants this type of thing and how I would call to look into this?
thanks! Mike
FeverMike is offline
Old 02-21-2008 | 04:59 PM
FeverMike's Avatar
Arrgh I called Julie at Throttle Up looking for a used stock Bravo 1 26p and she did not have one. Also found found the prop is only under warranty for a year. I guess I have to buy a new one.
Old 02-25-2008 | 04:45 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Yes the props are only warranted for 1 year. Call customer service at 920-929-5040 and see if they are willing to help. I used to work in that department. They can and most likely will say no but it is worth a shot. You will definately need a reciept if you get to that point. Good luck.
[email protected]
bbladesprops is offline
Old 03-08-2008 | 05:06 PM
Strip Poker 388's Avatar
Rob
I wonder if its one of the older props that was machined in the wrong direction, creating a stress risers and cracking?I ate 3 of them
http://www.offshoreonly.com/forums/s...ighlight=bravo
Attached Thumbnails Mercury Prop Warranty?-bolixi%2520race%2520%252cprop%252cetc%2520028.jpg   Mercury Prop Warranty?-prop%25209-7-04%2520003.jpg
Strip Poker 388 is offline
Old 03-10-2008 | 08:21 PM
Smile
Rob, we don't talk about that anymore. LOL
The stock props changed the machining process in the early 2000's stopping the TE failure. The Labbed propellers from Mercury Racing never had the issue because of the way we Lab Finished the Bravo 1's.
SIDENOTE.........X7 is a direct result.
[email protected]
Old 03-10-2008 | 08:23 PM
Rob
Brett whats x7?
Old 03-10-2008 | 08:30 PM
Smile
New Mercury stainles steel alloy.
[email protected]
Old 03-10-2008 | 08:39 PM
Rob
i guess the material holds up better on a lab prop?
Old 03-10-2008 | 08:42 PM
Smile
They will tell you so........
[email protected]
Sydwayz
08-18-2005 08:35 AM
sun 304
07-21-2005 06:01 PM
rivrbrat
5
03-04-2005 11:32 PM
BILL1134
1
07-03-2002 04:07 PM
