Eagle 25..need new prop! >
Old 04-10-2008 | 11:56 PM
Default Eagle 25..need new prop!
This is for any prop gurus out there, want an opinion...
Have a 25 eagle with the 525sc. Current setup is 27 mach 4 blade running 5400-5500 rpm at 81mph. Had the local guy add cup to get the bow up. Helped angle, but no speed gain. Think this prop is maxxed out?
My question is, boat planes easily now, and would like a bit more top end. Motor runs best between 4800-5200, according to mercury. Will be adding 7.5 psi pulley, and dana exhaust and MSD ignition this weekend. Am expecting to get even more past the recommended RPM after this.
So...should I consider a 3 blade merc labbed? 29 maybe? Want more top end, bottom to mid isn't really that important, don't like to launch the boat anyway.
Anyone have a testing program that allows you to buy the right prop??
Thanks!!!
Mike
Yellow_ICC_OK is offline
Old 04-12-2008 | 08:39 AM
hoozeyurdaddy's Avatar
before buying a 3 blade, I would try one, had similar boat with same engine package and the 3 blade would cavitate just as the bow would break and would have to back off the throttle until it settled in and it would cavitate during mild to sharp turns, 4 blade never loses water, try a 28 or 30 bravo 1 prop.
hoozeyurdaddy is offline
Old 04-12-2008 | 09:29 AM
i have 28 mach stern prop, that was checked by bblades, still in the box, we could trade for 27 . the blade is in great shape i have 26 also scott
fastscarab22 is offline
Old 04-13-2008 | 01:01 PM
Default hydro
i have a hydro Qv4 for xr 27p new in box $300
tony stamis is offline
Old 04-17-2008 | 03:58 PM
Default Scott
Sounds interesting! whats your email and I will hit ya up.
thanks!
Old 04-17-2008 | 04:09 PM
my email is [email protected] i have still in the box
Old 04-17-2008 | 04:22 PM
Default Check
Mail.
Thanks.
Old 04-18-2008 | 09:30 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
BBLADES offers a test program that allows boaters to test props with no strings attached.
The program will cost you $25 to borrow a propeller for 15 days (enforced). You learn from the testing and determine what way to go from there. You are not obligated to purchase from us in any way.
[email protected]
bbladesprops is offline
Old 04-18-2008 | 10:05 AM
Default Awesome
Am trading a nice OSO member my 27 for his 28. If that doesn't get it done I will definitely be calling you!! I would LOVE to try a 29 labbed or something, to see what happens. Need to keep my RPM under 5250.
thanks again for all your good work on this board
Elite Marine
Eliminator
8
05-06-2008 01:39 PM
boatnutt
Prop Talk
9
11-27-2007 11:37 PM
2boatpoor
Eliminator
4
09-13-2006 04:22 PM
Kokopelli
Eliminator
1
10-11-2004 01:19 PM
Linster
Eliminator
2
09-07-2002 08:56 PM
