speedmaster 3 prop >
speedmaster 3 prop
speedmaster 3 prop
Old 06-24-2008 | 05:52 PM
Originally Posted by bbladesprops
If the gear ratio is 1.35:1, the slip is 9%. That is very good. You need to raise the rpms by decreasing pitch. It is hard to believe you can only turn 28 inches of pitch to 4000 rpm with 1000HP. ??
We kind of found out what the problem is !
Bro has over 30% Slip.
The X dimension on the #3 way to low, sticking out about 5 inches below Hull !!!!!!
Gonna stick a #4 on there with a 31 Pitch prop and the Baby should fly @ 5500 RPM with over 100 MPH .
98% it should work ?!
DareDevil is offline
Old 06-24-2008 | 09:58 PM
it better work!
I think it will go well over 100, with the big power. If not i'm sinking it.
soley277 is offline
Old 06-24-2008 | 11:58 PM
Hell,you better look at that little crack !
Otherwise it will sink when you go 100 !!!!!!
nitrousnolan
03-24-2008 03:15 PM
Buddy OO
03-24-2007 05:08 PM
mondorally
12
01-06-2005 04:26 PM
z.zuperboat
1
10-05-2004 04:36 PM
greencard
1
08-31-2004 05:39 PM
