Hydromotive QIV Plus Thoughts?? >
Old 07-07-2008 | 04:00 PM
Fast Forward's Avatar
Default Hydromotive QIV X Thoughts??
I just ordered a 23p QIV X for my 26 Powerquest w/stock 454mag EFI. Just wonder if anyone else has any experience with one of these props on a single engine application.
I have been running a 23p & 21p Mirage plus with mixed results.
Fast Forward is offline
Old 07-07-2008 | 07:20 PM
I live somewhat near Hydromotive, They are some nice people over there.
I bought a Q1V a couple years back.
My cruise speed picked up nicely with the 4 blade and probably saves me a good little bit on gas.
Had my prop Rec. labbed by them in the spring, But I can't give you a comparison because I just rebuilt my engine before.
whoya is offline
Old 07-07-2008 | 07:25 PM
Are you running a standard QIV? What size boat ,prop & power are you running?
Old 07-07-2008 | 07:39 PM
509 9.5-1 comp. 23 Baja Not sure exactly on HP number. Im guessing around 500. 24 pitch
Far as I know they are still exchanging props for around $30. if it does not work out.
whoya is offline
Old 07-07-2008 | 08:08 PM
fountainfevr's Avatar
running that xact prop only left hand. Planes a little slow but well worth the gas milage I get. Pushes my boat 67 on the river got 73 out of it at KY lake. I think you will like it!
fountainfevr is offline
Old 07-08-2008 | 02:12 PM
What power are you running in the Fountain?
Old 07-11-2008 | 11:07 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
I assume you have the X series. That will be the better choice for your hull than the standard Q4.
[email protected]
bbladesprops is offline
Old 07-11-2008 | 09:08 PM
Yep your correct.Had a chance to run the 23p tonight and it's heading back.Little to big a wheel. Slower out of the hole than my 21 Mirage Plus. Very nice cruise speed however. 4000 rpm at 50mph. I'll have to double check tomorrow agin with the 21 but I beleive that one ran 45mph at the same RPM. Top was another story it was a little rough at 2-3' and all I could get was 54mph at 4400rpm. It was a handfull at that. I'm thinking maybe a 21p
tony stamis
Swap Shop
2
07-14-2008 09:12 PM
Toffen
Prop Talk
3
01-03-2008 08:25 PM
Rookie
5
06-20-2007 12:58 PM
tekfal23
Prop Talk
6
06-12-2006 12:56 PM
