420 baja best prop? >
420 baja best prop?
420 baja best prop?
Old 02-21-2009 | 11:19 AM
Registered User
Default 420 baja best prop?
Hi does anyone have any information on the best prop for a Baja 420. It has triple 502's with blowers and is pushing 640 hp each. I am completing a hull up restoration on the boat this winter; total new inside and out.
Thanks,
Tim
Roper is offline
Old 02-24-2009 | 05:27 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Sounds like a fun project.
You do have options with propellers for that hull. 3,4 and 5 blade props will work. I think ultimately you will prefer 4 blade props built specific to the boat. The 4 blades will harness the power of your blower motors better than the 3 blade prop. The 4 blades will offer better cruise numbers than the 3 blade props and will comparable top end if Lab Finished. Also, the 4 blades will be slightly easier on the drives than 5 blade props concidering the weight and HP you are dealing with.
Let us know if we can help you with test propellers.
Brett
[email protected]
bbladesprops is offline
customtouch
Baja
25
04-08-2014 02:54 PM
thisistank
Baja
45
04-19-2009 04:23 PM
slikcraft
01-08-2008 05:56 PM
jcimprover
Prop Talk
12
04-17-2005 08:19 AM
