27 Fountain Fever prop help >
Old 05-03-2009 | 12:20 PM
Originally Posted by SDFever
There's always the ying and yang for me. It's difficult if not impossible to have it all. Cuping the prop will give you better time to plane and hole shot but it will cost top end. Depends on who you are.
Thanks For The Info!!
fountain-fever is offline
Old 05-04-2009 | 11:05 AM
Those hydromotive props are mules out of the hole. Bravo props are much better - at least that was the deal with my 27.
29's are better with the hydro props. I was told to run nothing but bravo props on mine. Hydro provided too much stern lift.
apppedigree is offline
Old 05-04-2009 | 12:35 PM
I agree with this statment 100%
Griswald is offline
Old 05-04-2009 | 11:03 PM
Originally Posted by bbladesprops
Smaller pitch will often help with planning. However, if you run into the limiter at WOT, you will lose speed.
B
I too have this problem and have been looking into b-blades.Im hitting 65 on gps with about 3/4 fuel with one person onboard.Have tabs at 2 to 3 on indicators and the drive at about 4 to 5 WOT but hit rev limiter at about 3/4 throttle.Have tryed backing out and slowly increasing throttle but nothing seems to help.I have a 27 with a 496 ho with a 1:65 ratio and a 26p bravo 1.Any help would be gratly apperciated.would like to see low 70's if possible?
10K4U is offline
Old 05-05-2009 | 08:39 AM
My 27 which was a 94 stepped hull liked to have the drive at 3.5 and the tabs at 2.5 which was even with the bottom of the boat. I would suggest finding out where that is for you. Plane with the tabs buried and then raise them to even with the bottom of the boat to "extend the hull".
If your hitting the rev limiter while running WOT then maybe go up a pitch, see where you stand, your cruising speed will be better for sure anyways.
My opinion, and I dont mean to rain on anyones parade, 65mph, 68mph and 70mph, 75mph, theres not much difference. You need to remember that you have a 27' boat, it gets real hairy at the upper 80's and low 90's. Once you scare yourself you wont have fun with it anymore I promise and your girl wont either.
You can dick around with this thing all you want, I had 850hp in mine and it ran 95mph most days, but it was a handful, when you get done testing and breaking stuff and replacing drives, you could have a nice downpayment on something bigger that can take you to the next level. JMO
Old 05-05-2009 | 09:33 AM
You should be running a 28P bravo
Westcoast is offline
Old 05-05-2009 | 10:52 AM
whoops I reailized I mistyped that I meant Im running a rh 28p think I might try and find a freind with a 30p and see how bad getting on plane would be.I reailize it may not give me a million mph more but would like to see the speeds that fountain says.
10K4U is offline
Old 05-05-2009 | 01:20 PM
If you are running a 28p Bravo, also consider a 29Hydro Q4 for best top end stuff. Unfortunately, I just sold 2 of them.
Carder
Carder is offline
Old 05-05-2009 | 01:30 PM
Carder
will look into that as well.Thanks Carder.Also to the OP sorry for hijacking...haha
10K4U is offline
Old 05-05-2009 | 08:21 PM
U should up your membership.
SDFever is offline
