Identify a Herring prop >
Old 04-18-2009 | 10:10 AM
Strip Poker 388's Avatar
Rob
Question Identify a Herring prop
Abuddy of mine bought a 42 cig and claimed the props are 5 blade Herrings, they have no name just markings on inner hub,He said the hub is not removable They don't looked labed, I do not have a pick yet, I'm working on it,its unreal the people that have camera phones and cameras and don't know to take/send a pick.
Does these #'s mean anything to anybody?
11980
09 32 06
were assuming there 32's.The boat would barley plane!! Top rpm was 4500. I was told 30 bravos 4bld are stock on this boat ,he's trying my stock 30's this weekend to get a base line.
Rob
Strip Poker 388 is offline
Old 04-18-2009 | 11:39 AM
sean stinson's Avatar
The Illustrious One
Veteran: Navy
They should be sharp enough to cut you easily
Dying,....Is the day worth living for!!!!!!
sean stinson is offline
Old 04-18-2009 | 11:41 AM
The Illustrious One
Veteran: Navy
I cant remember exactly how to read the nimbers but I BELIEVE on is the year, one is pitch and the other ?????
Old 04-18-2009 | 03:05 PM
CB-BLR's Avatar
Chris
Call Jeff at Hering.
He has your exact answer.
714-894-5656
The prop was built in Sept of 2006 - It is a 32 pitch
The number on the top is the specific serial # that Hering uses for its records to record specifics on the prop, and any work done on it .
CB-BLR is offline
Old 04-18-2009 | 04:51 PM
Rob
714-894-5656
Thanks for the #.
Its is not sharp, the leading edge is sand blasted,about 1/8. Felling the blade its not real thin
Old 04-19-2009 | 06:05 PM
throttleup's Avatar
Produced in Sept. of 06, 32P.
throttleup is offline
Old 04-20-2009 | 12:21 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Yes on the dates.
The leading edge mark is a sanded LE used as a signature only. It isn't performance related.
[email protected]
bbladesprops is offline
Old 04-23-2009 | 04:32 PM
Rob
He tried my stock 30's 4blds , he said it was 100% better,I guess the pitch was just to much for it? He;s happy now
Old 04-23-2009 | 05:01 PM
Originally Posted by Strip Poker 388
Should have called bblades. props would have shown up set up right for the boat.
jeff1000man is offline
Old 04-23-2009 | 05:23 PM
Rob
The boat was bought from FastBoats with these props ready to run.
