Mirage vs. Mirage plus >
Old 07-23-2010 | 05:55 AM
Default Mirage vs. Mirage plus
Hi...What's the difference? Also, while I'm asking dumb questions, what is "labbing"? Thanks! Den
Den P is offline
Old 07-23-2010 | 10:09 AM
My understanding is that the mirage + has a little more cup built into the blades...lab finishing a propeller merely tailors it to your needs and fine tunes it .
HALLETT FAN is offline
Old 07-23-2010 | 02:46 PM
rchevelle71's Avatar
Mirage Plus also has the PVS Vent holes where the Standard mirage does not(or at least none of mine do). I have heard that a 21 Plus will run similar RPM wise to a 23 standard, seems like such on my boat, but its an eggbeater, so who knows??
rchevelle71 is offline
Old 07-23-2010 | 02:52 PM
hunster's Avatar
they also made a mirage ++ !!
hunster is offline
Old 07-23-2010 | 05:49 PM
Not all Mirage Plus's have the PVS vents. The Mirage Plus has a lot better bite due to cupping and a better design. A mirage Plus spins about 200rpm less than a standard Mirage to get the same speed.
Labbing is thinning and balancing the blades on a prop. There are recipe's for generic labbing and you can have a prop custom labbed based on the needs of your boat. It costs about $350 a prop, but when done right can get you better handling and top speed increases of 1-3mph.
Griff is offline
