Considering new props...what hubs? Does it matter? >
Old 11-28-2011 | 06:46 PM
Default Considering new props...what hubs? Does it matter?
I am considering trying a new set of props but I am wondering if there is any horsepower/speed limitation to mercruiser flo-torq hubs.
If I am say at 500 hp and 80 mph do I need solid hubs? If so, does mercury still make them? (these are not my #'s, I am just curious)
Baja226sport is offline
Old 11-28-2011 | 09:00 PM
Merc makes a solid hub insert for the flo torque props:
http://www.mercurypartsexpress.com/u...cury-p344.html
ndaniels is offline
Old 11-29-2011 | 12:48 AM
SFOcean's Avatar
Charter Member #394
I have one solid hub for $20 plus ride; maybe you could use it if you have the rest of the stuff...
http://www.offshoreonly.com/forums/s...solid-hub.html
SFOcean is offline
Old 11-29-2011 | 06:12 AM
There is for the plastic hubs, 400hp. Use solid hubs. Cheap insurance.
A.O. Razor is offline
Old 11-30-2011 | 01:01 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Mercury, recomends to go to solid with 400HP or more.
At BBLADES we recomend going to solid hubs at 300HP if possible. The plastic inserts can give out under the constant loads created from 300 HP also. If you decide to use plastic/delrin (which can be used with 500HP) keep spare inserts on board.
Brett
[email protected]
bbladesprops is offline
