Prop washer size >
Prop washer size
Prop washer size
Old 12-20-2011 | 01:33 PM
Default Prop washer size
Would anyone know what the part number is for a Merc # 6 Prop washer? or if you have the ID x OD and thickness that would also work. I need three.
ken sampson is offline
Old 12-20-2011 | 02:30 PM
http://www.mercurypartsexpress.com/u...er-p35871.html
Here you go.
Good luck with it. Very cool ride.
A.O. Razor is offline
Old 12-20-2011 | 03:29 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Part number 39817
We have them in stock at $11.47
Brett
[email protected]
bbladesprops is offline
Old 12-20-2011 | 09:06 PM
tcelano's Avatar
I just use these on my #5's:
http://www.mcmaster.com/#90107A038
$9.35 for 5 of them.
tcelano is offline
Old 12-20-2011 | 09:21 PM
OldSchool's Avatar
+100
Would you happen to know the diameter and thread for the #6 drive nut. It just a brass nylock nut.....but they charge a crazy amount for them!!!!!!!!!!!!!!!
OldSchool is offline
Old 12-20-2011 | 09:37 PM
Smile
The nut isn't 100% brass and has a heavy NyLock.
Height is important too.
The washer has a ID taper.
Props are expensive.
Make sure to replicate on every level.
Brett
[email protected]
Old 12-20-2011 | 11:34 PM
tcelano's Avatar
Thread should be 1"-14 UNF.
Like Brett says, the nut is a special part, probably bronze. That's a hard part to find elsewhere.
I've run stainless ones and just used lots of grease without any problems. I don't ever leave mine in the water though. My attitude towards it would probably be different if I was running brand new #6's vs old rebuilt #5's...
tcelano is offline
Old 12-21-2011 | 07:24 AM
OldSchool's Avatar
Brett
Got it. Thanks for the info guys!!
Old 12-22-2011 | 09:54 AM
I just found out the washer is not what I need. I need a spacer for the ASD-8 drive. Someone told me since I'm running the same Prop as the Merc 6 I could use that washer however I have both front load and rear load props so to keep all the washer-spacers the same I need spacers that will allow a slight slipping over the spline on the shafts. So this will have a slight recessed area in the washer. Thanks
Old 12-22-2011 | 10:05 AM
Smile
Call my friend and owner of Arneson Industry's
Rick @ 415-485-0788
B
[email protected]
