Will #6 Props Fit ARN-8 Surface Drives? >
Old 03-21-2012 | 07:29 AM
Default Will #6 Props Fit ARN-8 Surface Drives?
Hey guys.... Just like the title says, I'm looking to see if big shaft #6 props will fit on ARN-8 Surface Drives? Thanks in advance!
FastVee is offline
Old 03-21-2012 | 07:07 PM
I think the bushing is different but the spine is the same.
lightning jet is offline
Old 03-22-2012 | 03:10 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
ASD 8's had 3 configurations. Actually 4.
19 spline taper.
25 spline taper.
26 spline taper.
26 spline rear load bushing bore.
Count the splines and we can go from there.
Brett
[email protected]
bbladesprops is offline
Old 04-02-2012 | 01:16 PM
Would these adapters help?
Attached Thumbnails Will #6 Props Fit ARN-8 Surface Drives?-prop-apapters-1.jpg
CignificantOther is offline
Old 04-02-2012 | 07:33 PM
Smile
Similar but I think the splines are off.
Brett
[email protected]
Old 04-02-2012 | 08:32 PM
Upon closer inspection, I think you're right.
So what do they fit? These are 23 to 26 spline.
Attached Thumbnails Will #6 Props Fit ARN-8 Surface Drives?-prop-adapt-2.jpg   Will #6 Props Fit ARN-8 Surface Drives?-prop-adapt-3.jpg   Will #6 Props Fit ARN-8 Surface Drives?-prop-adapt-4.jpg
