Prop question >
Prop question
Prop question
Old 08-20-2012 | 06:59 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
What rpm at WOT are we looking for?
Brett
[email protected]
bbladesprops is offline
Old 08-20-2012 | 07:25 PM
im no prop expert,but try half fuel and 2 adults,as you'll never get best top speed with the boat loaded....jmo
pqjack is offline
Old 08-20-2012 | 08:19 PM
Brett is that speed right for a stock 454 roller motor? I was hoping to get closer to 50 MPH at 4800 rpm's if it is possible.
InstaGator is offline
Old 08-20-2012 | 08:21 PM
pqjack, I realize that I have the boat loaded to the hilt but trying to see what I'm going to get for top speed with this new motor.
Old 08-20-2012 | 08:45 PM
Smile
Multiple issues and more testing required.
Too much weight for testing but most important is the high slip % you are achiving at over 30%. You need to cut that in half. If the propeller was reworked or even repaired prior, some of that could be a issue.
Also, if we harness the slip number we will be using a smaller pitch propeller in order to get the rpm up to what ever number you are searching for.
13 hour day is up! Talk to you later.............
Brett
[email protected]
Old 08-20-2012 | 11:19 PM
Dtile's Avatar
Originally Posted by InstaGator
Brett, Thank you for your time & response. I will be putting SHOWTIME in the water this weekend. I'll put the 23P Mirage on before I head out to get the baseline stats and foward the results to you. Thanks for the advise on where to start. You're right this has been an interesting project to say the least. I ran a thread on my budget restoration project in the classic section, "Stinger 260 Facelift" check it out. Thanks again. Gator
nice motor...looks like a few intake manifold bolts are missing?
Though my sold boat a bit differnt last month, a baja 260, brett and I discussed a rev 4 when i had so much cavitation and slip. The 4 blade gave me a solid 9mph more with best performance at all curves (holeshot, top and, etc) it was labbed too...but locally. I beleive Brett could have done better lab job then my oldtimer, but he was down the street and took one day. I'm sending my next job to brett...twins 292 formula with stock 330's. have the Mirage and the bravo ones alreay stock and ready to be tweaked. Broke some ribs so cant boat for a few days while in ICU ...
Dtile is offline
Old 08-21-2012 | 03:43 PM
Dtile, I have no idea what those holes are for there are no matching holes behind them . There aren't any intake bolts missing though. Are you telling me you gained 9 mph with a four blade prop. Were you running a single 454 or twins? I would buy a four blade prop for the extra MPH no problem. I wish I knew where I could borrow one to test out. I'll have to see if anyone has one I can borrow. Thanks for the info...
Old 08-21-2012 | 03:57 PM
Brett would a 23P 4 blade Bravo 1 give me more speed and lower slip without over reving the motor?
Old 08-21-2012 | 04:27 PM
Dtile's Avatar
ya, was a single stock non mag bottom painted baja...It came with a mirage, not the plus. I first had the non mirage cupped and it gave me more lift and speed, about 4 mph...then used the 4 blade, gave me another 3-4 (eliminated cavitation at all speeds) then the lab gave me the rest...Though again, Baja hull...they are made a bit different and he might just use a mirage tweaked. I like the quick acceleration and better cruise speed now, though the top end is nice was still too slow for me. I could still use more bow lift I think..boat is sold...http://www.youtube.com/watch?v=zl6iCl0dufk&feature=plcp
Dtile is offline
Old 08-22-2012 | 05:50 AM
Gator,
Bravo one props only come in even numbers, 22, 24,26 etc. I PMd you back a few minutes ago. I will let ya know ASAP as soon as I hear back from the other gentlemen.
matthewr is offline
