Hydromotive Q IX  different versions!? >
Old 10-01-2012 | 07:44 PM
Default Hydromotive Q IX different versions!?
Ok I have to Hydromotive 24p q ix same serial number except one is left and one is right. I bought these used , seperately on here. One looks like it has been worked on but I don't know if it has been labbed, maybe just repaired. I made a template of the Right props blade and kinda traced it onto the Left so you can see how much different they are.
What should I do ? I like the rpms of the right one, can I have the left cut down? Oh also big difference is the Left props blades are further forward by 3/8ths of an inch on the prop. the blades are the same width at the body but they start and end sooner on it vs. the right blades.
The left prop has round ears and is 15.5 inches
The right prop has pointy ears and is 14.75 inches
the right prop turns 300-400 rpms more than the left and is right where i want to be.
Right
Left
Jg1000 is offline
Old 10-01-2012 | 07:57 PM
You have a Hydromotive QIV and a Hydromotive QIV-X, the X being the round ear model.
QIV is a cleaver stern lifter
QIV- X is like a Bravo 1, round ear bow lifter. Every thing happens at the stern so it isn't really a bow lifter but that is what people call it.
http://www.hydromotive.com/int_quad4.html
http://www.hydromotive.com/int_quad4X.html
marylandmark is offline
Old 10-01-2012 | 08:24 PM
Sorry but they are both Q4 and not Q4-x , one has been cut down . I have owned several of both
KEVLARKAT32 is offline
Old 10-01-2012 | 08:28 PM
yep kevlar is right they are bot non X props. Serial number...
Jg1000 is offline
Old 10-02-2012 | 12:42 AM
The top/RH prop has been modified to make it even more of a cleaver. They are both regular Q IV's.
Griff is offline
Old 10-02-2012 | 11:21 AM
what does that effect ?
Jg1000 is offline
Old 10-02-2012 | 12:53 PM
Being cut down will increase the rpms. Making it more of a cleaver will reduce bow lift. The Q IV is more of stern lifting prop anyway, so that may not matter.
Griff is offline
Old 10-02-2012 | 12:54 PM
I have an '89 Formula 292 SR1 with big blocks. Would you say that a stern lifting prop is probably best for my application?
Jg1000 is offline
Old 10-02-2012 | 03:58 PM
Sorry for the bad info, now that I am on a real computer screen (vs a dumb "WYSE" terminal), you are 100% correct in that they are both QIV.
