What prop for 32 fever >
Old 10-07-2012 | 05:12 PM
Fenderjack's Avatar
Pirate of the Chesapeake
Default What prop for 32 fever
We put our 32 back together with stock 454 power.The boat will run
68. on gps with 4 people and 1/2 tank.But motors are turning almost 5100 rpm running 15 1'2 x 25 mirage props. Want to get the rpm's down to about 4600.Do not want to loose any top end and boats comes right on plane easy now.I have my thoughts but need some back up.Think 26 mirage props or 4 blade bravos of a yet to be determined pitch.Stock bravos 1.5.1.JOHN SR
Fenderjack is offline
Old 10-08-2012 | 01:45 AM
What stock 454's???? 454mags, 330's??? 310's????
454mags should be spun to 5000-5100rpms at WOT for the best performance.
330's you want about 4700-4800rpms at WOT
Griff is offline
Old 10-08-2012 | 12:58 PM
Fenderjack's Avatar
NOT MAGS!! They are 454 blue waters They came out of a inboard boat believe they are 340s but nor sure I do know that 5200 is to much for inboard boats. JOHN SR
Old 10-08-2012 | 07:33 PM
Im wondering the samething. My 32 turns about 4800 and runs about 72 MPH right now. My perfomance sheet says she turned 5050 when it was tested and ran at 75 MPH. I'm trying to find just that little bit. Im think it should improve my mid range making it so I dont have to run her just that much easier at crusing speed. My motors are stock 502 MPIs
Lucky1456 is offline
Old 10-12-2012 | 10:08 PM
John you should check out the cutting edge props. Damn that 5 blade cleaver looks assume. It really just looks fast ahell to me. They really reasonable on there pricing as well.
Old 10-13-2012 | 01:34 AM
I would probably try some 26" Bravo 1's.
Griff is offline
Old 10-13-2012 | 03:05 PM
boat was os tested with the hydromotive 4 blade props..might want to give them a try..
FIXX is offline
Old 10-16-2012 | 03:18 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Fenderjack,
We can discuss your setup and offer you a variety of test options.
I feel the correct 4 blade propellers will get you right where you want to be.
Brett
[email protected]
bbladesprops is offline
