1996 22' Donzi Classic, 502 Mag, Bravo Drive
New to me Donzi Classic. She came with a 25p Mirage non plus. What other props work well on these old school boats?
Would like a 4 blade option even though the drive is set deep. |
fixx
Originally Posted by Pat McPherson
(Post 3834103)
(Post 3834103)
Thanks for the input guys.
I also was told over on Donzi.net that the Turbo 1 works well. The Rev 4 work well on my 24' Superboat so I was thinking it would work on this hull also. I have not run the boat yet as I just picked her up 10 days ago and she's now tucked away for the winter. The last owner only ran her a couple of times and didn't ever ring her out in calm water. Dave told me he had her up to around 68 at 4600rpm in rough water. I believe a 25p is the right size; seems to be what guys have on 22s with a stock 502. I need to deside if I should have the prop I have reconditioned or spend the $ on a new prop. I've worked with Brett before and had a vary good experience. |
I just check Brett's web page and the Turbo 1 is $287. That is probably not a whole lot more than reconditioning my Mirage. I don't know if a Merc hub kits works with a Turbo or if I would need to buy that too.
Brett, Please chime in with your thoughts. Are you running any specials to recon props over the winter? My prop is not bent but does have a few nicks and dents. It's likely the original 1996 prop that came with the boat from the factory. |
Sent my prop to BBlades
(Post 3834686)
Brett, Please chime in with your thoughts. Are you running any specials to recon props over the winter? My prop is not bent but does have a few nicks and dents. It's likely the original 1996 prop that came with the boat from the factory. Decided to send my prop out for him to check anyhow. |
He's probably enjoying a break for the holidays. Your prop is in good hands.
Subscribing. Very interested in results.
Pat,
Sorry for the delay in response. Your propeller is here and I have done a brief visual on it. It looks fine to the naked eye and to be stock. We will put it on the pitch block as well as other measuring devices and I will report back to you. I assume we will adjust it to the normal Lab recipe we typically use on these hulls. I'll get your ok and discuss this with you next week. We do have our winter special underway so the Lab cost would be $72 less than normal if you decide to go that route. Have a nice weekend. Brett |
labbing that 25 mirage will probably good a good option,i would loosen it up a little 200-300rpm when i had the boat out it was max out around 4600-4800,it was hot out and rough so it was hard to max it out,i did check the tach calibration and it was a little lazy about 100-150rpm,ther boat comes on plane easy and stays on plane at very low rpms,great cruise speed at 3000-3500rpm,i think labbing that prop would be an ideal set-up with the stock lower,now a -2 or -3 imco lower would probably see some good performance gains,anyone ever tried a -3 imco,we installed a -2 imco on another 22 and it worked great don't know exactly the gain because we also upgraded the 454 mag to a 540-600hp
| All times are GMT -5. The time now is 10:01 PM. |
