Prop slip % >
Prop slip %
Prop slip %
Old 12-02-2013 | 11:27 AM
Default Prop slip %
What are considered good slip #'s? I'm looking at 17-19% slip on my set up, seems not so good to me. Thought's???
05 Fountain is offline
Old 12-02-2013 | 11:47 AM
bbladesprops's Avatar
Offshoreonly Advertiser
05 Fountain.
Your slip% is slightly high. However, the numbers you are quoting are not that unusual for the 27 and 29 Fountain. In some instances we have the slip % to be allowable at 17% in order to gain the best top speed numbers. Sometimes dialing the slip numbers down on your hull do not benefit top speed but do make a difference in the mid range numbers.
I'd be happy to discuss the options with you if you wish to give me a call.
Brett
[email protected]
bbladesprops is offline
Old 12-02-2013 | 12:25 PM
I've spoke to you before Brett, I need to check Tach to see if it's reading right and then I'll call ya back. Thanks
