What prop for Pro Charged 253 Checkmate >
Old 03-26-2014 | 09:01 AM
Default What prop for Pro Charged 253 Checkmate
1997 Checkmate Convincor 253 / Procharged 502 with Lightning Headers / Bravo XZ 1.36 ratio. Does anyone have a similar set-up ? What size prop are you running?
hadleycat is offline
Old 03-27-2014 | 04:27 PM
bbladesprops's Avatar
Offshoreonly Advertiser
What kind of HP are we looking at?
Do you have any idea on the wet weight of the package?
Brett
[email protected]
bbladesprops is offline
Old 03-27-2014 | 09:14 PM
700 HP, Wet weight would be 4500 lbs. Thanks Brett you steered me right on my last boat.
Old 03-28-2014 | 03:22 PM
Ok,
You realize with that HP to weight ratio and hull design you are looking at a potential 100 mph set up.
You would need to turn a 30 pitch propeller at 5400 rpm with a 12% slip.
I'd bolt on anything in the 28 to 30 pitch range to get a base line and we can discuss the results and go from there.
Call me if you need a test propeller and we can help you out.
Brett
[email protected]
Old 04-03-2014 | 10:01 AM
A 253 with 700hp will run right around 85mph, what rpm do you need to turn? anything else done to motor?
id suggest 26p bravo 1...... @ 5400 and 85mph a 26p will be around 13% slip
sabo is offline
Old 04-03-2014 | 09:01 PM
Motor is bone stock with the lightning headers and pro charger, intercooler at 7 lbs. I am currently running a 30 pitch Bravo1 prop which seemed about right to me because I assumed I had a1.50 ratio outdrive. But when we opened up the out drive and it was a 1.36 it made me second guess my prop size. I have owned the boat a short time and really have not had it on any good wide open runs yet. I believe I still have the stock rev limiter which is 5150?
Old 04-07-2014 | 08:56 AM
At that rpm you still may be slightly over pitched, get some good runs in and see, but you should be somewhere around 85mph
sabo is offline
Old 08-13-2014 | 12:06 PM
hows it running?
sabo is offline
Old 08-13-2014 | 02:14 PM
Originally Posted by sabo
hows it running?
My drive is a 1.5 ratio. with the 30 Pitch I am about 82 mph at 5000 rpm. That where it starts leaning out. I am upgrading my fuel system right now.
Old 09-25-2014 | 10:08 AM
Where you able to get it dialed in? Does this hull have the notched pad/transom?
sabo is offline
