Hydro help >
Hydro help
Hydro help
Old 06-19-2014 | 12:35 PM
Default Hydro help
Just bought a hydromotive prop and am currently running mirage on a bravo 1 drive. Do I need any special thrust washer or hardware to swap these out? Thanks
ruepappy is offline
Old 06-19-2014 | 06:39 PM
All the hardware from the Mirage will work.
endeavour32 is offline
Old 06-23-2014 | 06:49 PM
bbladesprops's Avatar
Offshoreonly Advertiser
It actually depends on the vintage of each propeller.
In most cases over the last few years the attaching hardware is interchangeable as Hydromotive moved to the square bore FloTorq 2 hub assembly.
If one is a pressed in hub and one is square bore, you will need different stuff.
Brett
[email protected]
bbladesprops is offline
