Diffuser ring removal >
Old 07-25-2014 | 09:27 AM
Default Diffuser ring removal
I have a set of Ron Hill 15x30 Hammerheads (Bravo copy) that are vented for outboards. The props worked fine on my friends Talon Carrier CC cat which has a heavy inner liner. I have a Talon ex race cat and the Hammerheads, spinning out, cause the cat to buck from bow to stern. I have talked to a few friends who think the diffuser ring may be causing the bucking. The general concensus is to cut the diffuser ring off to eliminate the bucking. I would appreciate any educated opinions on the subject from Brett or anyone in the prop business.
Thanks Bob
bulletbob is offline
Old 07-25-2014 | 03:23 PM
ideally on a lathe if you have access to one
plasma cutter
grinder
pstorti is offline
Old 07-27-2014 | 09:55 AM
I know how to remove it. Just asking for input on what handling changes to expect after removal. Will it stop the porpoise or are the big ear four blade bravo design not the prop for my Talon. They are loads of fun for launching off of big lake chop. Two friends, in the know, are really impressed with the BBlade Blaster 4 blade. Smaller surface area props in comparison. My Talon responds best to clevers for refrence. Just wanted to get the most out of these props for a spare set.
Old 07-28-2014 | 02:29 PM
bbladesprops's Avatar
Offshoreonly Advertiser
If you are not experiencing any ventilation upon planning, remove .75" diffuser rings.
This will aid in decreasing the stern lift.
Typically the higher the engines are mounted the more stern lift the rings will induce as they become a extension of the gear case..
Brett
[email protected]
bbladesprops is offline
Old 07-29-2014 | 05:30 AM
Brett
Thank you sir for the reply and for getting my Spinelli's back to me in short order! a three week turn around is awesome!
Bob
Old 07-29-2014 | 09:24 AM
You're welcome. Too bad the shipping to and from add a extra week.
Enjoy,
Brett
[email protected]
Old 09-02-2015 | 06:13 PM
Spinelli Bros. Is open for business. Spinellipropellers.com
hang on is offline
