Those little rubber strips in a Mercury Flo-Torq hub >
Old 12-28-2014 | 06:37 PM
i have 2 mercury flo-torq chopper 2's (14x26),, going on 1997 mercury 200's,, what hub kit should i use? the delrin, solid.. i hears so many conflicting views?
quicklt1 is offline
Old 12-28-2014 | 08:39 PM
Do you have big shaft or small shaft? I have never seen solid hubs on a small shaft...might be wrong though. You would be fine with the regular flo torq hubs on 200's.
turbo rr is offline
Old 12-29-2014 | 11:00 AM
bbladesprops's Avatar
Offshoreonly Advertiser
You will be fine with the plastic delin insert.
If you desire to use stainless solid hub inserts you wil need the 15 spline aft adapter. Of course if you are running the old 14" chopper 1 props, you will have a pressed in 15 spline rubber hub already installed.
Let me know if you have any other questions.
Brett
[email protected]
bbladesprops is offline
