looking for FAST cruising prop ? for eliminator
I've talked to 2 cat guys recently and they both said the XR drives are a little weak for 5 blades. Is that true?
With your engines and that size boat no. I only had XZ drives on mine.
pstorti, your experience says you had same top speed with 29P 5 blade as a 30P 4 blade. Is that normal when you go to 5B should you go down 1 pitch?
Yes
I also loved your action on opening air intake, it even seems to my newbie eyes it's a little short on air intake.
Yes
Proves my point then, there is no substitute for testing props on your own boat, even the same model can be different from one to the next. on my 28 I hit a wall at 80mph with the Maximus, but since you have more power and its a 30 they worked.
well after talking to BBlades AND Bob Leach owner Eliminator, and a couple guys here I'm going with 34" 5 maximus. Seems to be the right blade for starters! MANY MANY thanks for everybody and looking forward for more improvements for my fast cruiser.
Seeing how I'm 65 and have boated for 60 of those years I've gotta stay out of the sun, so here's my next question, I have factory really nice hide away bimini top. stainless, proper length etc. Bob sez 60 MPH tops,mmmmmmmmm this boat doesn't come alive until 80!
Anybody ever see a custom permanent aluminum top, something like the newer cobalts on a catamaran? Yea, yea, I'm walking into that one but with my skin issues I'm gonna stay fast on water one way or the other! chuck
Look into whoever is the best welder in your area for T-tops and center console fishing boat rigging. I am sure they could make something work for you, but it would have to be made with studs through bolted into the gunwales. This would also allow you to remove it fairly easily. Remember, it's not just on the water that you have to worry about it, but on the trailer too, towing at highway speeds. The T-tops on the go-fast CCs often slow them down by 5 mph or so, and they also turn them into sailboats when on the trailer.
You may be better off investing in sun-block clothing.
[ATTACH=CONFIG]532544[/ATTACH]
Oh yea, the best guy is right across from my shop, he does incredible work here on the north side of Houston. All kinds of t tops, raised seating platforms of all kinds, built in rocket launchers and cup holders etc etc. Once I get a design I'm sure he'll be able to do anything I can come up with. I've just never seen a go fast of any kind with an aftermarket top on it. I've seen some big cruisers with add on hard tops that were absolutely perfect and looked like they came with the boat. Yea, get that on a cat! LOL!
Everything is for sale @ a certain $$
