looking for FAST cruising prop ? for eliminator >
Old 11-18-2014 | 07:49 PM
Sydwayz's Avatar
Forum Regulator
No experience, but ran across this in a magazine today:
www.hardtotop.com
Sydwayz is offline
Old 11-18-2014 | 09:41 PM
Originally Posted by dancing bear
great info, thanks guys. I have 2 new garmins and both said 92 mph, and a weird note, it also has Livorsi GPS speedo, it said 105. Weird. I trust the garmins more.
I've talked to 2 cat guys recently and they both said the XR drives are a little weak for 5 blades. Is that true?
So blindriver you say you like the 34's and wouldn't take them off. Have you tried 34 pitch 5 blade maximus on your4 boat? And how did they work?
pstorti, your experience says you had same top speed with 29P 5 blade as a 30P 4 blade. Is that normal when you go to 5B should you go down 1 pitch? I also loved your action on opening air intake, it even seems to my newbie eyes it's a little short on air intake.
I think your prop problem is mostly a GPS setting problem
92 nautical mph = 105.8 mph
Griff is offline
Old 11-22-2014 | 05:11 AM
Ha! That maybe all it is, waiting for a break in weather to take it out again and that will be first thing I check. (Houston: 70 degrees but thunderstorms all day)
dancing bear is offline
Old 11-22-2014 | 05:18 AM
Looking at the maximus 5 blade they have removable hard rubber plugs at front part of the hub, what are those for? I'm assuming to reduce cavitation if needed?
Old 11-22-2014 | 09:55 AM
for ventilation to break the props loose and get on plane easier, actually to create cavitation but only works at lower speeds doesn't make a difference at cruising speeds.
pstorti is offline
Old 12-14-2014 | 08:41 AM
My best results have been 5 blade hydro motive P5-X. Plane better with less blowout. Drop 2 pitch sizes for the 5th blade. I run 31's in the 5 blade and am at 120 on the 6k limiters. Ran about same speed with bravo 4 blades 34p. If someone wants my 34's I will sell them. Have about 5hrs on them mostly testing.
Eliminated572 is offline
Old 03-10-2015 | 07:31 PM
Out In havasu a lot of boats have some sections of Bimini in a mesh that air passes through easier. I had one made and ran it up to 90 mph with no problems .frame was all stainless. Still keeps sun out fine. Staps in front stainless braces for the rear.
jeff s is offline
