25p vs 23p, same wot rpm? >
Old 05-28-2015 | 10:23 PM
SB
Losing weight is the same as adding horsepower.
SB is offline
Old 05-28-2015 | 10:36 PM
Originally Posted by AWOL
Update part 3:
Still running under 5k rpm, but now in the 4800-4900 range. Being a novice and hauling this speed, Im more focused on not dying.
Life is good, and getting closer to my 65 goal.
that should be pretty close with a 23 and your rpm.
phragle is offline
Old 05-29-2015 | 08:11 AM
I'm pretty happy with it as it sits right now. I'm liking the 23+ now that I have my issues figured out and it seems to get up on plane faster than my 25, so its a good prop for my typical routine.
If there's ever down time or at the end of the season, that's where I may start tweaking further.
AWOL is offline
Old 06-16-2015 | 08:30 PM
Update again: Changed plugs, had some wind behind me today and got 64.9 on gps
AWOL is offline
Old 08-28-2015 | 08:33 AM
BUMP. Dinged up my 23+ so I picked up a regular 23 mirage to see if I could get it to 5000+ rpm.
Still no dice, but running 64.8 gps- so about the same speed and same rpm - which I find strange.
I wonder if my tach is off because I seem to get to the same rpm before it starts to blow out and need to tuck it back in some.
AWOL is offline
Old 08-25-2016 | 09:32 AM
Bump again.
Turns out the regular 23P Mirage I was running last year as a replacement was modified. It had more cupping added to it, essentially making it a 23 Plus. I purchased an untouched 23P and have been running consistently faster speeds this summer. Between cleaning the hull, running straight 93, and the help of some current, I hit my best last night of 69.
AWOL is offline
Old 08-25-2016 | 05:04 PM
you running in the river or the lake im on grand island my buddy has the same boat with a 502 mag dose 73 with 26 pitch bravo 1 prop
1hydroman is offline
Old 08-25-2016 | 05:53 PM
I used to run by the small boat harbor break wall, with the speed limit of 10mph now, I run west river by GI. I dry dock at Erie basin
AWOL is offline
Old 08-26-2016 | 08:19 AM
i run in west river to we have a good group i have a 26 profile the rest of my buddys have a 1979 p&j 25ft ,24 python ,25ft obsession cat,25ft outlaw and a couple of jet boats
Old 08-26-2016 | 11:57 PM
I could use more boat buddies. I also want to check out that other python.
Keep your eyes and ears peeled for me:
I took the pics, these are my hooligan friends
AWOL is offline
