Rubex hub for mirage prop? >
Old 06-22-2015 | 07:35 AM
Default Rubex hub for mirage prop?
Hello! Does anyone know if Rubex (102) hub fits mirage 25p plus (non solid hub) prop??
arttu is offline
Old 06-22-2015 | 11:47 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Why not use the FloTorq hub system?
Brett
[email protected]
bbladesprops is offline
Old 06-22-2015 | 11:51 AM
Cause having rbx-102 hub in my hands just now Isn`t Flo torq almost same? Please post if you have seen or heard about this type of combination, need to order prop fast!
arttu is offline
Old 06-22-2015 | 01:05 PM
We don't sell or use the Rubex inserts. I have to assume they will work with the correct hardware since they are to go into square bore hubs. Most companies have used Mercury's dimensions for that.
Make sure the Mirage you are looking at is a square bore not a round rubber hub.
Brett
[email protected]
Old 07-06-2015 | 08:14 PM
BUP
No problem using a Rubex prop hub for Merc's 350 hp and down especially compared to that Merc Plastic flow torque.
The Merc plastic flow torque for the money IMO is not that good compared to Rubex especially for stock low HP apps.
In my day use to sell about 100 to 200 per year of these Rubex hub kits without a problem and the Merc flow torque Plastic insert would crack over time especially on very light impact. Again stock apps 350 hp and below.
Watch the video below.
https://www.youtube.com/watch?v=GflLjvuOcN4
BUP is offline
Old 07-06-2015 | 08:27 PM
Smile
At BBLADES we recommend SS hub inserts over 300 HP. Mercury recommends SS over 400 HP.
The beauty of the Mercury Delrin insert is the ease of installation and the cost.
We also recommend keeping 1 or 2 extra inserts on board.
But most importantly is the ability for the Mercury Delrin insert to shatter upon impacts to save drive line components better than any rubber hub assembly.
Also, you don't need to re-torque a Delrin insert if you seat it properly and torque to 55 ft/lbs or slightly above as suggested by the video.
Brett
[email protected]
Old 11-07-2015 | 12:53 PM
I have question if you have a square bore mirage prop
with a rubber insert ,can you press out hub and use the delrin in that?
jekyl is offline
