Prop help for 27' Fountain >
Old 09-30-2015 | 04:25 PM
Default Prop help for 27' Fountain
Based on what everyone post about how fast their Boat runs ....... I need help !
96' - 27 Fountain 502 with a little motor work done
15 1/4 X 22 - on GPS would run 56 @ 4700 RPM
15 1/4 X 24 - on GPS would run 58 @ 4500 RPM
Any help I will take ! .......... Fountain claims the Boat should run 70 with my setup
David27Fountain is offline
Old 09-30-2015 | 07:47 PM
I think you are in the ballpark with the props. Based on your RPM's/speed are you sure your not missing something with the motor setup?
Feverz29 is offline
Old 10-01-2015 | 02:54 PM
I had both of those props on an '00 27 Fever and hit 70 with the 24's. I would start looking at the health of the engine.
ALL_IN! is offline
Old 10-01-2015 | 06:39 PM
Got it ............
Q) Were you Props 15 1/4 in Dia. ?
Q) What were you tabs set at ? ............... I was running with them all the way Up
Old 10-01-2015 | 06:42 PM
VoodooRob's Avatar
Hours on engine? Compression and leak down test?
VoodooRob is offline
Old 10-01-2015 | 06:51 PM
The Boat has around 400 total ............ the Original Owner did not keep accurate records so I'm not sure when he had Triple R Racing in Ill. do the engine work. I plan on doing Comp. test this winter
Q) Could it be I'm not getting enough Fuel to the Motor ........... I have Elec. Fuel Pump - Holly 7lbs. but I need to add Pressure Gauge to see where it's at ???
Old 10-01-2015 | 06:56 PM
What 502, Merc Mag or crate motor? Any idea on hp?
Padraig
Padraig is offline
Old 10-01-2015 | 07:17 PM
No. looking at the Invoice Triple R - replaced Pistons, Rings, Rod & Main Bearings, Timing Chain, Dart Heads and Balanced the Engine 502 Mag
Old 10-01-2015 | 07:33 PM
Something is wrong. My 1998 Velocity 280 with a 502 mag would run 68 no problem......light load a good chop and some work 72 was possible. Now I know Velocity is faster, but you, IMO should be at least mid sixtys.
Padraig
Padraig is offline
Old 10-02-2015 | 07:43 AM
Call Fountain and get your performance report. It will have all of that info for you. This is a great starting point to get the most performance out of your boat. Some say you'll never see these numbers, but it will be close based on my experience.
This is from my old 27.
ALL_IN! is offline
