Quicksilver Solid Hub Prop, Bravo 1 Drive *Thrust Washer*
Hello,
I made the conscious decision to purchase a solid hub 23P Quicksilver prop for my 454MAG, Bravo 1. Im starting to think the other 23 P Quicksilver Mirage prop I had was modified and not getting me in the rpm range I wanted. Stamped with an "FB" before part #.
My main concern is I do not have a thrust washer for the "new" solid hub prop (48 13246 A5 23P). The hub part is of a smaller diameter than my other prop (48 13704 A41 23P). I put the solid hub prop on the drive for poops and giggles and it fits great without any washer.
I was able to tighten it down without issue, but I didnt drop her in the water. So do I need a thrust washer for it?
Yes you do.
It may be already on the prop. Remove it and look.
Here is a link to the part you need available on our wed site.
http://bblades.com/shop/accessories/thrust-washer-2/
Brett
Brett
[email protected]
[email protected]
You can send it to us for Lab work and we can get the 200 rpm you need.
Brett
Brett
[email protected]
[email protected]
