Baja 272 454MPI (310 hp) Prop
Hmm.. What to Y'all think of this deal? Not the cost or anything.. but the Mirage 21 would have less cupping so it would spin a little higher RPM.. Would it be too much rpm?
Ok, this is a SINGLE 310 hp 454? At 20 inches pitch, 2 inches is 10% diff. You are hitting 3900. 21 (Lil less than 10% change from 23) will get you to 4250 or so. A 20 bravo would get you more around 4500. A 19 closer to 4700.
Tried a 4 blade Bravo on my 272. It hated it. Not enough bow lift
Tune a M/P to your needs with a good prop shop. It was the best I found for mine back in the day.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
Also, if you can't hit 4k at WOT, don't try. Engine is overloaded and could pop a head gasket. It is a performance boat hull. So you expect fast. But it has a sea ray sundancer engine in it. Cam-intake-exhausts should get 400 out of it fairly easy...in the mean time, there are 19 and 21 props all over ebay under 100 bucks. Alum, but...
Had a 252 islander with a 7.4mpi gen 6 , it had one of those mirage 23 on it also. Had to bury the throttle to get on plane with a good load of people and gas ,but it would eventually pull 44-4600 rpm , my 272 with a 502 mag pulls the 23+ to 5100 rpm , slight chop light load ect ect,
You might have a missing cyl or some low fuel pressure , or your tach just reads low
It gets on plane pretty easy and sounds healthy. I feel like if it was missing a cylinder or something along the lines of that I wouldnt hit the MPH im hitting. I would also think I would be able to tell if a cylinder was missing while running.. Maybe the RPM gauge is just off like others have said... Is the only way to tell what the RPM is to hook up a scan tool?
You can purchase cheap inductive tachs to compare your tach against.
Also, we can supply you with M+21's to test with through our test program if you desire.
Brett
[email protected]
[email protected]
