Thoughts on Prop sizing >
Old 12-14-2018 | 04:01 PM
fastlane40's Avatar
Default Thoughts on Prop sizing
Going from 454 Magnums at 365hp,factory 19p Mirages to
525efi's 550hp is a good starting point 23 Mirages?
fastlane40 is offline
Old 12-14-2018 | 04:04 PM
fastlane40's Avatar
Forgot to add 5200rpm upper limit for carbed Magnums
and 5400 for the 525's.
Old 12-14-2018 | 06:31 PM
I would get a good baseline with the existing props before you jump to a new unkown prop set. Sure, I understand more power may require more prop, but AT LEAST get a baseline with the new motors and old prop. THEN you can make a more educated decision.
Trash is offline
Old 12-14-2018 | 09:40 PM
fastlane40's Avatar
I just bought 23 Mirages to start with.19's will be way too small.
