Help with prop to Chris Craft 260 Stinger >
Old 07-06-2020, 11:42 AM
  #51
Originally Posted by resurrected
Can do some trimming on that
how much? Thank you
JohanSweden is offline
Old 07-06-2020, 12:56 PM
  #52
resurrected's Avatar
I don't have any real world experience with any external pickups, but as per instructions on mine: flush on the leading edge and down 12.7mm at the back
transom_pick-up.pdf
File Type: pdf
Last edited by resurrected; 07-06-2020 at 12:59 PM. Reason: forgot the decimal point!
resurrected is offline
JohanSweden (07-06-2020)
Old 07-06-2020, 09:11 PM
  #53
Received 1,821 Likes on 907 Posts
Your propshaft height is WAY high for regular V Bottom. You want to be 3-4 inches below the bottom. My Pantera was at 3.25 below and I spaced it another inch lower.
Griff is offline
Old 07-07-2020, 01:32 AM
  #54
Thank you. A bravo one standard lower will get me to 3,7” below bottom.
Does the extentionbox help something with my high propshaft height?
Old 07-07-2020, 11:21 AM
  #55
The extension box does allow you run about an inch higher, so at 3.7" below you should be good.
Griff is offline
Old 07-07-2020, 11:37 AM
  #56
Maybe the bravo one standard lower is the best option for my boat then..
Im going to try it if I see any improvements/changes with the spacer installed
Old 07-08-2020, 01:45 AM
  #57
I bet you will see a very slight improvement with the spacer.
I would think the standard lower should work well.
Griff is offline
Old 07-08-2020, 05:14 AM
  #58
I am worried about that yes...
I tried to count the gear ratio today.
If i spin the engine 1 turn, the propeller spins about 3/4 turn.
what is the gear ratio?
Old 07-08-2020, 06:14 AM
  #59
You should spin the input shaft 10 turns and have someone count the prop shaft rotations. That will give you a more accurate ratio
Old 07-08-2020, 08:47 AM
  #60
Thank you. One guy told me it is 1,5:1 if I spin the motor 1 turn and the prop turns 3/4.
I also trimmed my water pickup down today.
