Alpha SS Outdrive >
Alpha SS Outdrive
Alpha SS Outdrive
Old 01-02-2021 | 07:07 PM
Default Alpha SS Outdrive
Need help with prop choice. New to me 1999 Scarab 1, 21' with a 383 Stroker engine. Alpha SS outdrive, prop was a 4 blade SS but no clue what pitch it was, from measuring it looks like it was less than a 15" diameter. Any help from anyone that has a similar setup?
Stix is offline
Old 01-03-2021 | 01:25 AM
What is wrong with the current prop?? Does the prop have a part number on it or brand name??
Griff is offline
Old 01-03-2021 | 06:51 AM
The prop is currently at the bottom of the Gulf somewhere.. lol.. it spun off. Prop lock nut failure. Prop didn't have a name on it that I noticed before losing it.
Stix is offline
Old 01-03-2021 | 12:18 PM
What pitch you need will depend on what gear ratio the drive is. I would think you want to be around a 14.5 diameter.
Griff is offline
Old 01-03-2021 | 02:14 PM
SB
Your 383 build consists of ? 383’s can range from 325hp to 500hp.
Gear ratio ?
Have a friend nearby with several props and/or marina with prop swap program ?
SB is offline
Old 01-10-2021 | 04:37 AM
Try find 19" pitch merc revolution 4 to test.
JaniH is offline
